[OpenLayers-Dev] meeting results
Christopher Schmidt
crschmidt at metacarta.com
Tue Jan 22 17:58:42 EST 2008
A couple results from the meeting:
* LayerSwitcher improvements belong in a layerswitcher addin, not an
improved layerswitcher in trunk. We will add infrastructure and setup
for the way to do this shortly, but not immediately: in the meantime,
the tickets for the layerswitcher improvements have moved out into a
seperate "Addins" milestone
* 2.6 release blockers identified:
http://trac.openlayers.org/wiki/Release/2.6/Blockers
* Any ticket which has not been touched in > 4 weeks was moved to
2.7 milestone. If you are *actively working* on any of the tickets
in:
http://trac.openlayers.org/query?status=new&status=assigned&status=reopened&milestone=2.7+Release&order=priority
you need to make it clear, and move the ticket back to 2.6. "Actively
working on" means, in this case, "I expect to have a patch ready for
trunk within the next 2.5-3 weeks" so that it can be reviewed. "I'm
going to work on it" is not likely to be enough unless you have a
history of writing patches for OpenLayers, so please keep that in
mind.
* We will have another meeting a week from thursday, 1-31-08, at 4PM,
unless otherwise noted. At that meeting, we will do further triage:
it is expected that no ticket not in the 2.6 milestone during that
meeting will be completed for 2.6.
* As always, http://trac.openlayers.org/wiki/Release/2.6 lists the
current tickets in the 2.6 release: If you can help, or are working
on these, please share and show so we can start cutting these tickets
down.
* There are three issues we did not cover completely: #902, #967, and
#1111. Please start a conversation for these tickets on the mailing
list if you're interested in them. (I'll start them off if no one
else does, but probably not tonight.)
* Note that if your ticket 'needs more work', it can still get bumped
before the next meeting! Please try to move patches forward in some
visible way.
We currently have 42 tickets marked for 2.6. I'd prefer to see that
number go down, rather than up. Patches, reviews, comments, etc. are all
useful. Let's make it happen!
The current release plan is still to do an RC1 by the end of the second
week in february.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
