[OpenLayers-Dev] Patch for Proj4js gauss projection
Martijn van Oosterhout
kleptog at gmail.com
Sat Jan 26 14:30:45 EST 2008
While attempting to use EPSG:28992 with proj4js I noticed it was
returning complete garbage. A bit of tracing revealed it was due to
the gauss.js code assuming it got and returned points in degrees,
whereas the caller and the rest of the code assumed radians. The
following patch fixed the problem for me.
Thanks in advance,
Martijn van Oosterhout <kleptog at gmail.com> http://svana.org/kleptog/
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080126/edd4b285/proj-gauss.bin
More information about the Dev
