[OpenLayers-Dev] Patch for Proj4js gauss projection
Mike Adair madair at dmsolutions.ca
Mon Jan 28 09:36:10 EST 2008
Martin,
Yes that was an issue in the gauss code and the fix is now committed to
the proj4js svn.
Developers should be aware that not all of the projection class code has
been verified/tested/validated yet.  I am working on completing that as
time permits and the need arises.
For the record, as of today, the following projection classes work (or
should work).  These are the 'proj=' parameter in the proj
initialization string: utm, lcc, tmerc, merc, stere, gauss, sterea, aea.
And the following classes are not validated yet: aeqd, eqdc, equi, laea,
mill, moll, omerc, ortho, poly, sinu, vandg
Mike
Martijn van Oosterhout wrote:
> Hi,
> While attempting to use EPSG:28992 with proj4js I noticed it was
> returning complete garbage. A bit of tracing revealed it was due to
> the gauss.js code assuming it got and returned points in degrees,
> whereas the caller and the rest of the code assumed radians. The
> following patch fixed the problem for me.
> Thanks in advance,
More information about the Dev mailing list
