[OpenLayers-Dev] tween, panTo, animated panning
Eric Lemoine
eric.c2c at gmail.com
Wed Jan 30 18:20:14 EST 2008
On Jan 30, 2008 11:09 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> If I understand you correctly, in the general case setCenter will be
> called with the cancelTween option set to true. However, the eachStep
> callback in panTo will pass cancelTween:false to setCenter. Am I
> correct?
> Based on Chris' proposal for #967, we should be able to add this
> cancelTween option to setCenter.
#967 includes a new patch that might help you. Apply the patch and add
some code in the moveTo method to cancel animation if cancelTween is
true. What do you think?
Eric
More information about the Dev
