[OpenLayers-Dev] properties not set in map object (maxScale, minScale ...)
Eric Lemoine eric.c2c at gmail.com
Wed Jul 2 10:20:02 EDT 2008
Hi Pierre. Are they set in the layer object? (i think so, although i
dont have OL code handy). Eric.
2008/7/2, Pierre GIRAUD <bluecarto at gmail.com>:
> Hi,
> Is there any good reason why we don't set the minScale, maxScale, and
> some others properties ?
> If those properties are not set in the config options, they are never
> set dynamically. Though, it would be easy to compute them.
> For example, given an array of scales in the config, it would be easy
> to know what the min and max scales are.
> The reason I ask that for is because I would like to have a map with
> metric units, a scales options, and a layer with only a minScale (See
> http://trac.openlayers.org/ticket/1199). With the attached patch the
> determined numZoomLevels is negative, because the minResolution is
> greather than the maxResolution.
> Thanks,
> Pierre
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
