[OpenLayers-Dev] extra '?' in loadURL ?
Eric Lemoine eric.c2c at gmail.com
Fri Jul 11 00:30:01 EDT 2008
Hi Guillaume. It shouldn't be there but a ticket should be created for
this :-) In the mean time, and if this is causing you trouble, you can
use OpenLayers.Request.GET directly. loadURL may become deprecated in
the future so using the Request object as of now might be a good idea.
Thanks for the report. Eric
2008/7/11, Guillaume Sueur <guillaume.sueur at neogeo-online.net>:
> Hi devs,
> I've been using the loadURL for a while without any problem. After a
> recent update to last SVN version, I noticed the url sent had an extra
> '?' added at the end :
> alert(url) before loadURL gives:
> ../mapview/info/?X=314.99999999999983&Y=305.0000000000039&BBOX=337918.13584105,7652844.79930825,378081.86415895,7681155.20069175&WIDTH=759&HEIGHT=535&layers=9,4,5
> but the url sent to the server is (as seen in firebug, copied with Copy
> Location ) :
> ../mapview/info/?X=314.99999999999983&Y=305.0000000000039&BBOX=337918.13584105,7652844.79930825,378081.86415895,7681155.20069175&WIDTH=759&HEIGHT=535&layers=9,4,5?
> see the extra '?' at the end of it (yes, I know, the line is long...)
> what is it there for ?
> thanks
> Guillaume
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
