[OpenLayers-Dev] extra '?' in loadURL ?
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Fri Jul 11 03:11:23 EDT 2008
ok, I will ! But you know, you're never sure in this sort of case, after
having upgraded, to be in front of a bug or of a misconfiguration of
your script regarding new options !
Thanks,
Guillaume
Eric Lemoine a écrit :
> Hi Guillaume. It shouldn't be there but a ticket should be created for
> this :-) In the mean time, and if this is causing you trouble, you can
> use OpenLayers.Request.GET directly. loadURL may become deprecated in
> the future so using the Request object as of now might be a good idea.
> Thanks for the report. Eric
> 2008/7/11, Guillaume Sueur <guillaume.sueur at neogeo-online.net>:
>> Hi devs,
>> I've been using the loadURL for a while without any problem. After a
>> recent update to last SVN version, I noticed the url sent had an extra
>> '?' added at the end :
>> alert(url) before loadURL gives:
>> ../mapview/info/?X=314.99999999999983&Y=305.0000000000039&BBOX=337918.13584105,7652844.79930825,378081.86415895,7681155.20069175&WIDTH=759&HEIGHT=535&layers=9,4,5
>> but the url sent to the server is (as seen in firebug, copied with Copy
>> Location ) :
>> ../mapview/info/?X=314.99999999999983&Y=305.0000000000039&BBOX=337918.13584105,7652844.79930825,378081.86415895,7681155.20069175&WIDTH=759&HEIGHT=535&layers=9,4,5?
>> see the extra '?' at the end of it (yes, I know, the line is long...)
>> what is it there for ?
>> thanks
>> Guillaume
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
