[OpenLayers-Dev] new mapfish server code
Eric Lemoine
eric.c2c at gmail.com
Fri Jul 11 11:07:51 EDT 2008
Hi Sanjiv
I just created a ticket with a patch which, among other things, reduce
the size of the template code.
<https://trac.mapfish.org/trac/mapfish/ticket/184>
Would you mind giving this code a spin and check if that works for
you? Look at python/mapfish/templates/model.py_tmpl and
python/mapfish/templates/controller.py_tmpl after you have the patch
applied to understand how to use the new code.
Thanks,
Eric
More information about the Dev
