[OpenLayers-Dev] new mapfish server code
Eric Lemoine eric.c2c at gmail.com
Fri Jul 11 11:53:18 EDT 2008
Sorry. Wrong mailing list again. Eric
2008/7/11, Eric Lemoine <eric.c2c at gmail.com>:
> Hi Sanjiv
> I just created a ticket with a patch which, among other things, reduce
> the size of the template code.
> <https://trac.mapfish.org/trac/mapfish/ticket/184>
> Would you mind giving this code a spin and check if that works for
> you? Look at python/mapfish/templates/model.py_tmpl and
> python/mapfish/templates/controller.py_tmpl after you have the patch
> applied to understand how to use the new code.
> Thanks,
> Eric
More information about the Dev mailing list
