[OpenLayers-Dev] Problem with custom select and modify controls binding to same onModification event
Arnd Wippermann arnd.wippermann at web.de
Wed Jul 16 14:48:27 EDT 2008
have a look at this threat at the reply from Oscar.
http://www.nabble.com/Re%3A--OpenLayers-Trac---OpenLayers---1483%3A-ModifyFeature-control-makes-SelectFeature-control-to-modify-features-to17863300.html#a17863300
Arnd Wippermann
Mark K. Zanfardino wrote:
> My apologies if this is a duplicate message.  I posted a similar email
> before I'd joined the devel mail list and can't confirm if it was sent
> to the list or not.
> NOTE: OpenLayers 2.6 - I am using the selection control and the modify
> control on the same map. I have written custom behaviors for each of
> these two controls.  I'm finding that the selection control calls the
> onModificationX events which are registered to the modify control and
> not the selection control.  With console.log I can observe that when I
> choose the select tool and select a given polygon the onModificationX
> functions are called.  If I omit the modification tool altogether select
> calls the appropriate onSelect event.
> This behavior can be viewed at
> http://crschmidt.net/mapping/wpserverdemo/.  Simply draw a polygon,
> choose the select tool then select the newly drawn polygon.  You will
> note that the modify handles will be available and that you can modify
> the polygon.  This is the same behavior as that of the modify tool.
> Mark K. Zanfardino
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://www.nabble.com/Problem-with-custom-select-and-modify-controls-binding-to-same-onModification-event-tp18471132p18494122.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
