[OpenLayers-Dev] [vector-behavior] proposal for changes
Tim Schaub
tschaub at opengeo.org
Wed Jul 16 15:49:29 EDT 2008
Hey-
Thanks for summarizing your ideas Eric.
Eric Lemoine wrote:
> Hello
> I'd like to bring a few changes to the vector-behavior code. Before
> making these changes, I wanted to describe them and give everyone a
> chance to speak up. Here they are:
> * remove update() and commit() from the strategy API. Just like
> controls and handlers, strategies are activated/deactivated through
> activate()/deactivate().
Agreed. This is already how we're using strategies.
> * remove property 'strategy' from Layer.Vector, strategies are set in
> the 'strategies' properties (Array)
Also agreed.
> * make Layer.Vector responsible for creating, destroying, activating
> and deactivating its strategies. (a) Today Layer.Vector.setMap()
> activates the strategies but never deactivates them; instead,
> Layer.Vector should override removeMap() and deactivates the
> strategies in there. (b) To make Layer.Vector responsible for creating
> and destroying the strategies, Strategy classes as opposed to Strategy
> instances must be passed to the Layer.Vector constructor, I would go
> with:
I agree with the layer activating and deactivating strategies. We could
also include an autoActivate property (default is true).
On strategy destroy, I'd like to talk a bit more. I know passing
classes and options is an explicit way to ensure nobody is left with a
reference to a destroyed instance - but it is also a bit restrictive.
The paging strategy (for example) exposes some stuff that is not easily
accessible through the layer. Chris and I talked about this and thought
that having application developers keep a reference to the strategy was
a good solution. So you could do things like:
strategy.pageNext();
The alternative is to put method(s) on the layer that either 1) expose
the strategies in a handy way, or 2) expose strategy methods.
An implementation of 1 would let you do something like:
layer.getStrategiesByClass(/Paging/)[0].pageNext();
The shortcoming here of course is that you're not guaranteed to get the
right strategy.
An implementation of 2 would let you do something like:
layer.pageNext();
This is originally how I wrote the paging strategy (it would add methods
to the layer). Since this was considered distasteful, I changed it in
favor of forcing app developers to keep a reference to the strategy.
I think the current solution is a better one (keeping a reference to the
strategy and calling methods directly on it) than either 1 or 2 above.
Interested to hear what you (and others) think.
I don't really mind if the layer destroys strategies (and protocols)
even if it didn't create them. I know Erik (and likely others) don't
like this - with good reason.
A third solution (which went nowhere before and would be a radical
departure from the current coding style) would be to write some adapters
that would allow something like:
IPaging(layer).pageNext();
(This of course requires on paging strategy per layer - in which case
solution 1 above would always work anyway.)
Anyway, some things worth considering before passing functions instead
of objects.
Tim
> new OpenLayers.Layer.Vector({
> strategies: [{
> class: OpenLayers.Strategy.BBOX,
> options: {ratio: 4}
> class: OpenLayers.Strategy.Save
> * make Layer.Vector responsible for creating and destroying its
> protocol. In the same way as above, a Protocol class as opposed to a
> Protocol instance is passed to the Layer.Vector constructor:
> strategies: [{
> options: {ratio: 4}
> protocol: OpenLayers.Protocol.HTTP,
> protocolOptions: {url: /path/to/service}
> * remove the setLayer() method from the Strategy base class.
> Vector.Layer will do something like that:
> for (var i = 0; i < this.strategies.length; i++) {
> var strategy = new this.strategies[i].class({
> layer: this,
> * make Layer.Vector responsible for creating/destroying the format
> instance. Again, a format class as opposed to a format instance is
> passed to the Layer.Vector constructor.
> * remove the setFormat() method from the Protocol class. The format
> instance is passed at protocol creating using new
> OpenLayers.Protocol({format: format}).
> Thoughts?
> Thanks,
> Eric
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
> !DSPAM:4033,487c5cdb99535409313003!
More information about the Dev
