[OpenLayers-Dev] Re size & Rotate Feature
Arnd Wippermann
arnd.wippermann at web.de
Tue Jul 22 17:56:05 EDT 2008
to rotate a feature I take the center of the bounds of the feature:
function RotateFeature(feature, angle)
var objBounds = feature.geometry.getBounds();
var x = (objBounds.left+objBounds.right )/2;
var y = (objBounds.top +objBounds.bottom)/2;
var origin = {};
origin.x = x;
origin.y = y;
feature.geometry.rotate(angle, origin);
feature.layer.drawFeature(feature);
Arnd Wippermann
Brian Levy-2 wrote:
> When resizing and rotating a feature, would it be possible to anchor from
> the center of the polygon? Currently the anchor point is on the first
> vertex. Any thoughts on this would be greatly appreciated!
> Thanks!
> Brian
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://www.nabble.com/Resize---Rotate-Feature-tp18578507p18599624.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
