[OpenLayers-Dev] SVG viewbox problem with minScale
Alexandre Dube
adube at mapgears.com
Fri Jul 25 15:14:50 EDT 2008
Hi everybody,
I use Firefox ( big fan ).
Of what I understand, each time I zoom in or out a map that has a
vector layer, the left and top values of the rederer's viewbox are
reseted to 0.
I have a WFS layer with a minScale: 49999 in my map. So, the first
time I get inRange of my layer, left and top are reset to 0. If I pan,
they change their value and if their value is 15000 pixels away from my
original left-top, no feature will be drawn.
The problem is if I zoom out of my minScale: 49999, my layer becomes
inactive. Zooming out don't reset the left-top values.
So, if I pan to somewhere else and then zoom in until I get inRange of
my minScale, my WFS layer shows no features because it's as we didn't
zoom at all ( the resolution is the same that the time we zoom out of
range ) . But, if I zoom in again once, then the features appear
(because the resolution has changed, and left-top are reseted to 0). If
I zoom out once, the features are still there.
I think the line 504 in SVG.js should be changed. Instead of doing
nothing if not inValidRange, it should check again by ignoring the
resolution. That would resolve the issue, I think...
Any comments ?
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
