[OpenLayers-Dev] SVG viewbox problem with minScale
Alexandre Dube
adube at mapgears.com
Mon Jul 28 16:45:09 EDT 2008
Hi Eric,
The location is correct. It is ok to have a 15000px limit and that
works perfectly.
To fix the bug, I think when the code checks the resolution, if it's
the same than before, it should also check the location of one of our
feature position... If it's near our 15000px limit ( let's say more
than 14000px for example ) it should change the left-top value of the
renderer.
That way, even if we zoom out or pan, if we get out of our 15000px
limit, features will continue to be displayed.
What do you think ?
Alexandre
Eric Lemoine wrote:
> On Mon, Jul 28, 2008 at 3:35 PM, Alexandre Dube <adube at mapgears.com> wrote:
> So it seems to me that the problem doesn't really related to the 15000
> px limit. In this scenario:
> - go out of range
> - pan and zoom without going beyond the 15000 px limit
> - go in range (the features should be visible as the limit was crossed)
> is the location of features correct?
> Eric
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
