[OpenLayers-Dev] Please,
help with vectors projection over google layer (really desperate)
Esteban olm
esteban.olm at gmail.com
Fri Jun 6 08:25:08 EDT 2008
Hello,
I need help! I can not understand why I can not see a line in openlayers.
If I don't use projections, I can see it, but then the line is not properly
drawn in Firefox (but yes in Explorer).
I know that problem is a projection problem (I have read a lot in Internet),
I know Google use Mercator, but I don't know how to solve it.
Please help !! There is something I can not find.
Here is the entire HTML page from what I think is the best approximation
(but it doesn't draw the line):
<html>
<head>
<title>prueba</title>
<!-- this google key is fo HTTP://LOCALHOST, so it should go in your PC
<script src="
http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAAdktgbP3W_jzENycyyxYmhT2yXp_ZAY8_ufC3CFXhHIE1NvwkxQAmpwRv0-s77497-2GnWVaa_ulwA"
type="text/javascript"></script>
<script src="http://openlayers.org/dev/OpenLayers.js"></script>
<script type="text/javascript">
var lat=42.508;
var lon=1.118;
var map; //complex object of type OpenLayers.Map
function init() {
//Initialise the 'map' object
map = new OpenLayers.Map ("map", {
controls:[
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.PanZoomBar(),
new OpenLayers.Control.Attribution()],
maxExtent: new
OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34),
maxResolution: 156543.0399,
units: 'm',
projection: new OpenLayers.Projection("EPSG:900913")
var layergoogle = new OpenLayers.Layer.Google("Google Normal",
{ type: G_NORMAL_MAP },
'sphericalMercator': true,
'projection': new OpenLayers.Projection("EPSG:900913")
var vectores = new OpenLayers.Layer.Vector ("Vector Features",
{ 'projection': new OpenLayers.Projection("EPSG:4326"),
'displayProjection': new
map.addLayer(layergoogle);
map.addLayer(vectores);
//line near Barcelona, spain, for example
var p1 = new OpenLayers.Geometry.Point(2, 41);
var p2 = new OpenLayers.Geometry.Point(41, 2);
var points = [p1,p2];
var lineString = new OpenLayers.Geometry.LineString(points);
var lineFeature = new OpenLayers.Feature.Vector(lineString,
null, null);
features = [lineFeature];
vectores.addFeatures( [features] );
var lonLat = new OpenLayers.LonLat(2, 41)
map.setCenter(lonLat, 7);
</script>
</head>
<body onload="init();">
<div style="width:500px; height:300px" id="map"></div>
</body>
</html>
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080606/8b2cae86/attachment.html
More information about the Dev
