[OpenLayers-Dev] Please,
help with vectors projection over google layer (really desperate)
Eric Lemoine
eric.c2c at gmail.com
Fri Jun 6 09:48:17 EDT 2008
2008/6/6 Esteban olm <esteban.olm at gmail.com>:
> Hello,
> I need help! I can not understand why I can not see a line in openlayers.
> If I don't use projections, I can see it, but then the line is not properly
> drawn in Firefox (but yes in Explorer).
> I know that problem is a projection problem (I have read a lot in Internet),
> I know Google use Mercator, but I don't know how to solve it.
> Please help !! There is something I can not find.
> Here is the entire HTML page from what I think is the best approximation
> (but it doesn't draw the line):
See my comments in the code.
> <html>
> <head>
> <title>prueba</title>
> <!-- this google key is fo HTTP://LOCALHOST, so it should go in your PC
> <script
> src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAAdktgbP3W_jzENycyyxYmhT2yXp_ZAY8_ufC3CFXhHIE1NvwkxQAmpwRv0-s77497-2GnWVaa_ulwA"
> type="text/javascript"></script>
> <script src="http://openlayers.org/dev/OpenLayers.js"></script>
> <script type="text/javascript">
> var lat=42.508;
> var lon=1.118;
> var map; //complex object of type OpenLayers.Map
> function init() {
> //Initialise the 'map' object
> map = new OpenLayers.Map ("map", {
> controls:[
> new OpenLayers.Control.Navigation(),
> new OpenLayers.Control.PanZoomBar(),
> new OpenLayers.Control.Attribution()],
> maxExtent: new
> OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34),
> maxResolution: 156543.0399,
> units: 'm',
> projection: new OpenLayers.Projection("EPSG:900913")
> var layergoogle = new OpenLayers.Layer.Google("Google Normal",
> { type: G_NORMAL_MAP },
> 'sphericalMercator': true,
> 'projection': new OpenLayers.Projection("EPSG:900913")
Place the 'type' and 'sphericalMercator' properties in the same
object. Remove the 'projection' property.
'type': G_NORMAL_MAP,
> var vectores = new OpenLayers.Layer.Vector ("Vector Features",
> { 'projection': new OpenLayers.Projection("EPSG:4326"),
> 'displayProjection': new
You do not need any options for the vector layer:
var vectores = new OpenLayers.Layer.Vector ("Vector Features");
> map.addLayer(layergoogle);
> map.addLayer(vectores);
> //line near Barcelona, spain, for example
> var p1 = new OpenLayers.Geometry.Point(2, 41);
> var p2 = new OpenLayers.Geometry.Point(41, 2);
> var points = [p1,p2];
> var lineString = new OpenLayers.Geometry.LineString(points);
Reproject your line string before creating the feature with it:
lineString.transform(
> var lineFeature = new OpenLayers.Feature.Vector(lineString,
> null, null);
> features = [lineFeature];
> vectores.addFeatures( [features] );
> var lonLat = new OpenLayers.LonLat(2, 41)
Either pass mercator coordinates to the LonLat constructor or
reproject it before passing to setCenter:
lonLat.transform(
> map.setCenter(lonLat, 7);
> </script>
> </head>
> <body onload="init();">
> <div style="width:500px; height:300px" id="map"></div>
> </body>
> </html>
Hope this helps,
Note that I haven't tested anything so there might still be errors lurking.
Eric
More information about the Dev
