[OpenLayers-Dev] beyond ajax
Christopher Schmidt
crschmidt at metacarta.com
Mon Jun 9 16:15:28 EDT 2008
On Mon, Jun 09, 2008 at 02:03:00PM -0600, Tim Schaub wrote:
If you are using any of these in your code, it is highly recommended
that you change that, because these methods don't work consistently
under IE: The XML format handles all this much better.
> Alternative to OpenLayers.parseXMLString:
> Use the OpenLayers.Format.XML parser (read method).
> OpenLayers.Ajax.getElementsByTagNameNS:
> Use the OpenLayers.Format.XML parser (getElementsByTagNameNS method).
> OpenLayers.Ajax.serializeXMLToString:
> Use the OpenLayers.Format.XML parser (write method).
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
