[OpenLayers-Dev] @require issue with XHR code
Tim Schaub
tschaub at opengeo.org
Tue Jun 10 19:38:30 EDT 2008
Tim Schaub wrote:
> Sure, done.
> I'd be interested to see the profile that loads only Ajax.js and its
> dependencies.
Having said that - I do see the point in maintaining backwards
compatibility in build profiles that used loadURL and no other classes
that would have required it.
Thanks for the diligence.
Tim
> Tim
> Eric Lemoine wrote:
>> Tim, thanks for adding the appropriate @requires XMLHttpRequest.js. I
>> think one is still missing in Ajax.js - loadURL requires the Request
>> object.
>> Eric
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
> !DSPAM:4033,484f0fe126811096210785!
More information about the Dev
