[OpenLayers-Dev] arbitrary element as marker?
Paul Spencer
pspencer at dmsolutions.ca
Tue Jun 17 09:21:35 EDT 2008
Is it possible to use an arbitrary HTML element (say a div containing
several images) as a marker? My use case is that I have several
different styles of marker images and then some overlay images that
add a numeral or letter on top of the marker. OpenLayers.Marker uses
OpenLayers.Icon, which will only show an single image.
I could put two markers in the same location but that seems horribly
inefficient.
I could also probably use a Point feature and override the styling but
it seems like a lot of effort to get a reasonably simple effect.
If it is not currently possible to do this then I will implement it -
any suggestions? Seems like the simplest method would be to subclass
or modify the Icon class to allow for an arbitrary element.
Cheers
Paul
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://www.dmsolutions.ca/
More information about the Dev
