[OpenLayers-Dev] vector labels
Piebe de Vries
piebe.de.vries at geodan.nl
Mon Jun 30 05:10:31 EDT 2008
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080630/4bd43ba7/attachment.html
Index: Elements.js
--- Elements.js (revision 6549)
+++ Elements.js (working copy)
@@ -151,6 +151,9 @@
this.root.appendChild(node);
this.postDraw(node);
+ // draw potential label
+ this.drawLabel(node, geometry, style);
} else {
node = OpenLayers.Util.getElement(geometry.id);
if (node) {
@@ -210,6 +213,32 @@
return this.setStyle(node, style, options, geometry);
+ * Method: drawLabel
+ * Draws a potential label if set in style
+ * Parameters:
+ * node - {DOMElement}
+ * geometry - {<OpenLayers.Geometry>}
+ * style - {Object}
+ drawLabel: function(node, geometry, style) {
+ if (labelsVisible) // HACK
+ if (style.label)
+ this.drawText(node, style, geometry.getBounds().getCenterPixel());
+ else
+ if (style.label)
+ this.removeText(node, style)
* Method: postDraw
* Things that have do be done after the geometry node is appended
Index: SVG.js
--- SVG.js (revision 6549)
+++ SVG.js (working copy)
@@ -464,6 +464,50 @@
node.setAttributeNS(null, "d", "");
+ * Method: drawText
+ * This method is only called by the renderer itself.
+ * Parameters:
+ * style -
+ * location - {<OpenLayers.Geometry.Point>}
+ drawText: function(node, style, location) {
+ var resolution = this.getResolution();
+ var x = (location.x / resolution + this.left);
+ var y = (location.y / resolution - this.top);
+ var label = this.nodeFactory("label" + node.id, "text");
+ label.setAttributeNS(null, "x", x);
+ label.setAttributeNS(null, "y", -y);
+ if (style.fontColor) {
+ label.setAttributeNS(null, "fill", style.fontColor);
+ if (style.fontFamily) {
+ label.setAttributeNS(null, "font-family", style.fontFamily);
+ if (style.fontSize) {
+ label.setAttributeNS(null, "font-size", style.fontSize);
+ if (style.fontWeight) {
+ label.setAttributeNS(null, "font-weight", style.fontWeight);
+ /* No need to scale Text... */
+ label.setAttributeNS(null, "transform", "scale(1, -1)");
+ // prevent label duplication
+ if (label.firstChild) {
+ label.removeChild(label.firstChild);
+ var data = document.createTextNode(style.label);
+ label.appendChild(data);
+ node.parentNode.appendChild(label);
* Method: getComponentString
Index: VML.js
--- VML.js (revision 6549)
+++ VML.js (working copy)
@@ -552,6 +552,52 @@
node.path = path.join("");
+ * This method is only called by the renderer itself and must only
+ * be called after the node is append to renderer.root
+ * Parameters:
+ * style -
+ var label = this.nodeFactory("label" + node.id, "v:oval");
+ label.style.left = (location.x /resolution).toFixed() ;
+ label.style.top = (location.y /resolution).toFixed();
+ var textbox = this.createNode("v:textbox");
+ var span = document.createElement('span');
+ span.style.color = style.fontColor;
+ span.style.fontFamily = style.fontFamily;
+ span.style.fontSize = style.fontSize;
+ span.style.fontWeight = style.fontWeight;
+ span.innerHTML = style.label;
+ textbox.appendChild(span);
+ label.appendChild(textbox);
CLASS_NAME: "OpenLayers.Renderer.VML"
More information about the Dev
