[OpenLayers-Dev] vector labels
Zer
hcan at hotmail.com
Mon Jun 30 19:45:32 EDT 2008
Thanks Piebe!
I tried your code and that turned out to be a bi surprise! At first i could
not see any lables at all. But when I zoomed in, the labels where there. Not
placed on the vectors, but still there.... What really confused me was how
they all were written in Russian! :-) That was... until I took a closer look
and saw that all labels were mirrored and upside-down! Hehe..... Kind of
fun!
I think there must be something wrong, or something missing, with your code.
I will take another look into it tomorrow!
-Z
Piebe de Vries wrote:
> Besides its speed, I found the rendering of labels to work fine.
> I have extracted the needed changes from the sandbox, I am not
> completely sure but I think the attached diff includes all the
> adjustments needed to get labeling going. However it also includes a
> quick hack: labels will only be drawn if labelsVisible is true. I had
> to include this since rendering the labels (as is all the vector
> rendering) is awfully slow especially in IE, so I had to give the user
> the option to turn of labeling.
> Enable labeling by doing something like:
> var context = {
> getTitle: function(feature) {
> return "blabla "
> + feature.attributes['titel'];
> var
> template = {
> label : "${getTitle}"
> , fontColor: "yellow"
> , fontWeight: "bold"
> var style = new
> OpenLayers.Style(template, {context:
> context});
> var styleMap =
> new OpenLayers.StyleMap(
> 'default': style,
> select: { fillColor: '#ff0000',
> externalGraphic:"blabla.png", graphicHeight: 20}
> layer = new OpenLayers.Layer.WFS( "Blabla",
> host + "geoserver/wfs", {typename: 'bla:bla'},
> typename: 'bla',
> featureNS: ' http://bla.bla.bla ',
> extractAttributes: true,
> styleMap: styleMap
> Good luck,
> Piebe
> Zer wrote:
> Hi!
> I also need this function. Has anything more been done since April? What
> is
> left to be done?
> -Z
> Pierre GIRAUD wrote:
> Hi Piebe,
> You're right, there was no activity on this feature since december.
> In my opinion, there won't be any if there is no clear and loud demand
> for that, or if there's no fund given.
> Though, I think the code doesn't require much work to be ready to go into
> trunk.
> It's currently available in a sandbox. Don't hesitate to try a merge
> against current trunk version and to play with it !
> Regards,
> Pierre
> Index: Elements.js
> --- Elements.js (revision 6549)
> +++ Elements.js (working copy)
> @@ -151,6 +151,9 @@
> this.root.appendChild(node);
> this.postDraw(node);
> + // draw potential label
> + this.drawLabel(node, geometry, style);
> } else {
> node = OpenLayers.Util.getElement(geometry.id);
> if (node) {
> @@ -210,6 +213,32 @@
> return this.setStyle(node, style, options, geometry);
> + * Method: drawLabel
> + * Draws a potential label if set in style
> + * Parameters:
> + * node - {DOMElement}
> + * geometry - {<OpenLayers.Geometry>}
> + * style - {Object}
> + drawLabel: function(node, geometry, style) {
> + if (labelsVisible) // HACK
> + if (style.label)
> + this.drawText(node, style, geometry.getBounds().getCenterPixel());
> + else
> + if (style.label)
> + this.removeText(node, style)
> * Method: postDraw
> * Things that have do be done after the geometry node is appended
> Index: SVG.js
> --- SVG.js (revision 6549)
> +++ SVG.js (working copy)
> @@ -464,6 +464,50 @@
> node.setAttributeNS(null, "d", "");
> + * Method: drawText
> + * This method is only called by the renderer itself.
> + * Parameters:
> + * style -
> + * location - {<OpenLayers.Geometry.Point>}
> + drawText: function(node, style, location) {
> + var resolution = this.getResolution();
> + var x = (location.x / resolution + this.left);
> + var y = (location.y / resolution - this.top);
> + var label = this.nodeFactory("label" + node.id, "text");
> + label.setAttributeNS(null, "x", x);
> + label.setAttributeNS(null, "y", -y);
> + if (style.fontColor) {
> + label.setAttributeNS(null, "fill", style.fontColor);
> + if (style.fontFamily) {
> + label.setAttributeNS(null, "font-family", style.fontFamily);
> + if (style.fontSize) {
> + label.setAttributeNS(null, "font-size", style.fontSize);
> + if (style.fontWeight) {
> + label.setAttributeNS(null, "font-weight", style.fontWeight);
> + /* No need to scale Text... */
> + label.setAttributeNS(null, "transform", "scale(1, -1)");
> + // prevent label duplication
> + if (label.firstChild) {
> + label.removeChild(label.firstChild);
> + var data = document.createTextNode(style.label);
> + label.appendChild(data);
> + node.parentNode.appendChild(label);
> * Method: getComponentString
> Index: VML.js
> --- VML.js (revision 6549)
> +++ VML.js (working copy)
> @@ -552,6 +552,52 @@
> node.path = path.join("");
> + * This method is only called by the renderer itself and must only
> + * be called after the node is append to renderer.root
> + * Parameters:
> + * style -
> + var label = this.nodeFactory("label" + node.id, "v:oval");
> + label.style.left = (location.x /resolution).toFixed() ;
> + label.style.top = (location.y /resolution).toFixed();
> + var textbox = this.createNode("v:textbox");
> + var span = document.createElement('span');
> + span.style.color = style.fontColor;
> + span.style.fontFamily = style.fontFamily;
> + span.style.fontSize = style.fontSize;
> + span.style.fontWeight = style.fontWeight;
> + span.innerHTML = style.label;
> + textbox.appendChild(span);
> + label.appendChild(textbox);
> CLASS_NAME: "OpenLayers.Renderer.VML"
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://www.nabble.com/vector-labels-tp16589123p18206561.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
