[OpenLayers-Dev] svn build problems
Erik Uzureau
euzuro at gmail.com
Mon Mar 3 16:34:20 EST 2008
Sounds funky. Is this from a fresh checkout of trunk/ ? I just did a build
on a fresh checkout and had no issues.
Erik
On 3/3/08, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Hi all,
> I have been getting the following issue in svn trying to run ./build.py
> full.cfg
> woodbri at carto:~/work/openlayers/ol-svn/trunk/openlayers/build$
> ./build.py full.cfg
> Merging libraries.
> [snip lots of files]
> Resolution pass 1...
> Importing: OpenLayers/Format/XML.js
> Traceback (most recent call last):
> File "./build.py", line 34, in ?
> merged = mergejs.run(sourceDirectory, None, configFilename)
> File "../tools/mergejs.py", line 190, in run
> content = open(fullpath, "U").read() # TODO: Ensure end of line @ EOF?
> IOError: [Errno 2] No such file or directory:
> '../lib/OpenLayers/Format/XML.js'
> Does this indicate something needs to be fixed, maybe the user :) in
> this case.
> -Steve W
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
