[OpenLayers-Dev] svn build problems (SOLVED)
Stephen Woodbridge woodbri at swoodbridge.com
Wed Mar 5 14:27:09 EST 2008
Thanks all,
Problem solved. I nuke the old directory and did a clean checkout.
Everything now build nice and clean now.
-Steve
Erik Uzureau wrote:
> Sounds funky. Is this from a fresh checkout of trunk/ ? I just did a build
> on a fresh checkout and had no issues.
> Erik
> On 3/3/08, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>> Hi all,
>> I have been getting the following issue in svn trying to run ./build.py
>> full.cfg
>> woodbri at carto:~/work/openlayers/ol-svn/trunk/openlayers/build$
>> ./build.py full.cfg
>> Merging libraries.
>> [snip lots of files]
>> Resolution pass 1...
>> Importing: OpenLayers/Format/XML.js
>> Traceback (most recent call last):
>>   File "./build.py", line 34, in ?
>>     merged = mergejs.run(sourceDirectory, None, configFilename)
>>   File "../tools/mergejs.py", line 190, in run
>>     content = open(fullpath, "U").read() # TODO: Ensure end of line @ EOF?
>> IOError: [Errno 2] No such file or directory:
>> '../lib/OpenLayers/Format/XML.js'
>> Does this indicate something needs to be fixed, maybe the user :) in
>> this case.
>> -Steve W
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
