[OpenLayers-Dev] handlers and onselectstart
Christopher Schmidt crschmidt at metacarta.com
Mon Mar 3 17:46:28 EST 2008
On Mon, Mar 03, 2008 at 03:42:14PM -0700, Tim Schaub wrote:
> Hey-
> Bart van den Eijnden (OSGIS) wrote:
> > Hi list,
> > currenly only the Drag Handler has code to make sure the map does not get
> > selected (and turns blue in IE).
> > Is this not something that should be more general, maybe even in Handler.js?
> See also http://trac.openlayers.org/ticket/1378.  I assume the
> regression you're talking about (1410) was also introduced in
> http://trac.openlayers.org/changeset/6176.
I sort of doubt that IE's selection model takes -moz-user-select: none
into account. #1410 (as described in the comments to the ticket) was
caused by http://trac.openlayers.org/changeset/5772 .
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
