[OpenLayers-Dev] kamap scale threshold - svn-02 29 2008
Raj Chundur
rajchundur at gmail.com
Wed Mar 5 15:27:28 EST 2008
We have an application that works fine with the following code. However,
testing it with the subversion trunk downloaded on feb 29th,
Setting the maxscale and min scale on the kamap layers results in getting an
"invalid array length" error.
Appreciate any help in this matter. Not sure if this is a bug
thank you
var options = {
maxExtent: new OpenLayers.Bounds(1310280, 377296, 1471285, 484991),
scales:
[192000,144000,96000,72000,48000,24000,12000,9600,4800,3600,2400,1200,600,300],
units: 'ft',
var map = new OpenLayers.Map($('map'),options);
var lyr1= new OpenLayers.Layer.KaMap(
'Aerial Photos',
['http://cagismaps.hamilton-co.org/kacache'],
{'tilesource':'cache','metaTileSize':
{w:6,h:6},'fileextension':'.jpg','i':'JPEG','map':'mapbase_orthos','g':'Aerial
Photos'},
{'isBaseLayer': false,'opacity':1,'buffer':2,
'minScale':300,'maxScale':192000}
var lyr2= new OpenLayers.Layer.KaMap(
'Civil Boundaries',
'http://cagismaps1.hamilton-co.org/kacache',
{w:6,h:6},'fileextension':'.png','i':'png24','map':'mapbase','g':'Civil
Boundaries'},
{'isBaseLayer': false,'opacity':0.6,'buffer':2,
'minScale':12000,'maxScale':192000}
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080305/0982bef3/attachment.html
More information about the Dev
