[OpenLayers-Dev] Xlink sous IE
Christopher Schmidt crschmidt at metacarta.com
Thu Mar 6 08:54:42 EST 2008
On Thu, Mar 06, 2008 at 01:39:27AM -0800, fgenin wrote:
> Yes , I use the SVG adobe viewer to display SVG in IE. And the SVG image is
> defined in this documentation
> http://www.w3.org/TR/SVG/struct.html#ImageElement
The Adobe SVG plugin does not support compound documents. This means
that you can only view the SVG in a seperate .svg file, *not* inline
with the HTML.
In the end, it sounds very much like you are dealing with something that
is completely outside the realm of OpenLayers. IE does not support SVG
in any way that interacts with OpenLayers (because it has to be in a
seperate object), so there is nothing that the OpenLayers mailing list
can do to help you.
Please look into contacting an SVG mailing list or something similar
instead.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
