[OpenLayers-Dev] 2.6 Open Ticket Summary
Christopher Schmidt
crschmidt at metacarta.com
Thu Mar 13 00:37:38 EDT 2008
I will be doing one of these every 2 days or so until we have an RC1.
This is a summary of the tickets listed on
http://trac.openlayers.org/wiki/Release/2.6
* Tickets To Review Query:
#1410: Path Handler can result in selection of map
Patch from bartvde; improved by elemoine. No review yet.
#1411: WMC: hidden is not always correctly interpreted
Patch from crschmidt to add layerOptions as seemingly
described by Tim. No review yet.
#1418: dragging mode of modify feature control is broken
Patch from elemoine. crschmidt tested, looks okay, but has
no idea what the code should look like. Still needs review.
* Tickets To Commit Query:
#1360
SVG renderer draws features in the upperleft corner of the
map pane when coordinate outside range
* Tickets which Need More Work:
#1364: zoom responce is delayed when you have a lot of
OpenLayer.Layers on the map.
It looks like we've lost a fair chunk of speed when zooming
the map in 2.6 vs. 2.5 when working with many layers. It's
not entirely clear to me why this is, and my toolchain is
not helping me: need some help doing accurate profiling and, if
possible, nailing the revision when it dropped.
#1426: KML icons misalign with hotSpot nodes
I think this one may actually be the result of #1428, but
can't confirm: there's an issue where
http://dev.openlayers.org/sandbox/euzuro/pop/examples/sundials.html
is not displaying anything in IE6 or IE7.
#1428: request.fileType check forces parsing of request.responseText
This was causing test failures in IE6 earlier today, though
I can't reproduce it now.
* Tickets which Need Discussion:
#1378: clicking next to the map causes selection of controls
Need some advice on best path to solving this problem: some
solutions proposed in tickets.
#1431: Features that fail the SVG renderer's inValidRange check
will not be redrawn when recentering the map
This is not a regression; I'm in favor of pushing it off to
post-2.6.
* Outstanding Tickets Query:
#926: Google Style Popups
Two major outstanding issues:
* Weird black coloration of blocks in IE. I think this might be
because the contentDiv is for some reason having a background-color:
I feel this way in part because the CloudAmber (semi-transparent)
popups show a 'darker' color in the entire area the popup is.
* Miscalculation of popup or contentDiv size causes scrollbar to go
outside of popup instead of inside.
#1387: rename test pages
Not directly related to release
#1429: untiled layer with minScale/maxScale does not always clear
Regression from 2.5, though I'll admit I'm slightly confused
on the expected behavior.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
