[OpenLayers-Dev] Web-based Configuration using Mapbuilder for
GSoC 2008
Cameron Shorter
cameron.shorter at gmail.com
Thu Mar 13 18:18:32 EDT 2008
Hello Mathew,
Nice to meet you and great to hear this project is of interest.
In my opinion, understanding of good programming practices and design is
more important than specific language issues which can be learned as you
code. The structure of Java is similar to Javascript which will give you
a good start. Probably the best way to start is to read some tutorials
and have a look at the code in existing applications. (Things like
inheritance are done differently in javascript).
Understanding XSL will be beneficial for the Mapbuilder parts of this
project.
http://trac.openlayers.org/wiki/Documentation
http://docs.codehaus.org/display/MAP/Developers+Guide
http://docs.codehaus.org/display/MAP/Tutorials
(Plenty of pages here, I don't suggest you read them all yet)
Tharindu Mathew wrote:
> Hi,
> I'm interested in this project and is looking for an oppurtunity to
> learn the technologies associated with this project. But my experience
> with JavaScript is limited. I have manly used Java as my language and
> worked with XML web services, spring framework, etc in Java.
> Will my limited JavaScript experience be a problem in this project? If
> not, how may I gather more knowledge for this project?
> Regards,
> Tharindu
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
More information about the Dev
