[OpenLayers-Dev] Openlayers 2.5 doesn't draw vectors correctly in firefox and opera??? but ok in Explorer !!!
Esteban olm esteban.olm at gmail.com
Tue Mar 25 13:34:49 EDT 2008
Hi!
No, I haven't solved the problem, and it's very important for me, but I
haven't finded any solution :(
I have not been able to solve this problems, but... no one has the same
error???
I'm very surprised nobody has answer with the same problem !!
I don't do any coordinates convertion, so I don't now how to do it, but I
can not undestand how is possible nobody has seen this... bug?
PLEASE HELPPPPPP !!! :)
2008/3/25, Lynn ERD <lynn.dewitt at noaa.gov>:
> Hi Esteban,
>   Have you been able to solve this problem?  I am seeing exactly the same
> thing.  Vectors drawn on the Google satellite base layer are fine in IE
> but
> "move" when you pan in Firefox.  I have never had this problem with any
> other base layer.  I've tried several things mentioned in some other
> lists,
> including converting to spherical mercator, with no luck.
> Lynn
> Esteban olm wrote:
> when I insert a vector in the vector layer, ONLY IN EXPLORER is
> drawn ok, in firefox and in opera the vector...
> ... layer doesn't fin correctly in the center of the marker (the point
> wich
> represents the center of the marker is also a vertex of the vector).
> And yes, I have centered the icon in the map :).
> The problem is that the layer "moves" when I pan the map.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080325/01e0fa5a/attachment.html
More information about the Dev mailing list
