[OpenLayers-Dev] problems with drawing on layers
Eric Lemoine
eric.c2c at gmail.com
Sun May 18 17:36:51 EDT 2008
2008/5/18 Darko Radiceski <radiceski at gmail.com>:
> Dear all,
> I used the spherical-mercator.html example as a starting point to display
> few maps from VE and Google. Then following the example for drawing features
> called draw-feature.html i created few layers with the intention to draw
> some polygons on the map from an external application. I convert the Polygon
> feature in the right projection that the map uses but the feature is not
> visible on the map.
> Is there anything imidiately wrong that i am doing here?
Not that I see.
> Also what i noticed was when i turn on the drawing for a point the point
> just flashes on the map temporarily and dissapears.....However that point is
> supposed to stay on the map after clicked.
> Is there any explanation for this?
> What i did just as a test is this: I created a map sample project that uses
> the EPSG:4326 projection and only using the WMS layer from OL(not
> displaying VE or Google) when i used the same code as previously to add
> polygons to the layer they get added correctly. There must be someting i am
> doing here. Can someone point me in the right direction please?
Without code to look at it is kinda hard to help you.
Eric
More information about the Dev
