[OpenLayers-Dev] problems with drawing on layers
Darko Radiceski
radiceski at gmail.com
Sun May 18 16:28:50 EDT 2008
Dear all,
I used the spherical-mercator.html example as a starting point to display
few maps from VE and Google. Then following the example for drawing features
called draw-feature.html i created few layers with the intention to draw
some polygons on the map from an external application. I convert the Polygon
feature in the right projection that the map uses but the feature is not
visible on the map.
Is there anything imidiately wrong that i am doing here?
Also what i noticed was when i turn on the drawing for a point the point
just flashes on the map temporarily and dissapears.....However that point is
supposed to stay on the map after clicked.
Is there any explanation for this?
What i did just as a test is this: I created a map sample project that uses
the EPSG:4326 projection and only using the WMS layer from OL(not
displaying VE or Google) when i used the same code as previously to add
polygons to the layer they get added correctly. There must be someting i am
doing here. Can someone point me in the right direction please?
Much apreciated.
Sincerely
Darko Radiceski
Radiceski Darko
University of Wollongong
Australia
SIFE - UOW Chapter - Alumni
CASUAL ACADEMIC STAFF TEACHING - UOW SITACS
(School of Information Technology and Computer Science,University of
Wollongong)
Univeristy of Wollongong - Alumni
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080519/083c5086/attachment.html
More information about the Dev
