[OpenLayers-Dev] Geonetwork and Openlayers/Mapfish?
Mathieu Coudert
mcoudert at gmail.com
Wed May 21 06:01:30 EDT 2008
Hi Cameron,
It is neither in OpenLayers svn nor in GeoNetwork svn. :(
Maybe François-Xavier you have any idea about how to make this code
available?
On Tue, May 20, 2008 at 10:06 PM, Cameron Shorter <cameron.shorter at gmail.com>
wrote:
> Thank you Mathieu for responding.
> Where is the functionality that you are describing?
> Is it in the Geonetwork svn, or maybe Openlayers svn?
> Mathieu Coudert wrote:
>> Hi Cameron,
>> Indeed It is true that we had a look on it. We integrated Openlayers in
>> Geonetwork in order to perform geographical search, defining bbox criteria
>> using Openlayers. We also looked into the georss search in Geonetwork,
>> displaying results in Openlayers.
>> For specific needs, we implemented Openlayers as WMS viewer in Geosource
>> (GeoNetwork including profil for France).
>> Openlayers, at this time, does not provide Intermap advanced
>> functionnality such as PDF printing, web map context and map annotations,
>> this is a current limitation.
>> Concerning Mapfish, there is no plan to integrate it as a GUI for
>> Geonetwork but interaction between both will probably be developed in the
>> coming month.
>> Cheers,
>> Mathieu
>> On Tue, May 20, 2008 at 2:23 PM, Cameron Shorter <
>> cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>> wrote:
>> Openlayers developers,
>> LISAsoft has been hired to improved the User Interface for Geonetwork
>> and we will be kicking off the project tomorrow.
>> Jeroen tells me that Camp2Camp has already been looking into
>> building a
>> GUI for Geonetwork. Is this true?
>> If so, what is the state of this Camp2Camp work? Where are you up
>> to? Do
>> you have anything that we can contribute to or build upon?
>> Cameron Shorter
>> Geospatial Systems Architect
>> Tel: +61 (0)2 8570 5050
>> Mob: +61 (0)419 142 254
>> Think Globally, Fix Locally
>> Commercial Support for Geospatial Open Source Solutions
>> http://www.lisasoft.com/LISAsoft/SupportedProducts.html
>> Dev mailing list
>> Dev at openlayers.org <mailto:Dev at openlayers.org>
>> http://openlayers.org/mailman/listinfo/dev
>> Mathieu Coudert
>> mcoudert at gmail.com <mailto:mcoudert at gmail.com>
> Cameron Shorter
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080521/7713891d/attachment.html
More information about the Dev
