[OpenLayers-Dev] Geonetwork and Openlayers/Mapfish?
Cameron Shorter
cameron.shorter at gmail.com
Tue May 20 16:06:15 EDT 2008
Thank you Mathieu for responding.
Where is the functionality that you are describing?
Is it in the Geonetwork svn, or maybe Openlayers svn?
Mathieu Coudert wrote:
> Hi Cameron,
> Indeed It is true that we had a look on it. We integrated Openlayers
> in Geonetwork in order to perform geographical search, defining bbox
> criteria using Openlayers. We also looked into the georss search in
> Geonetwork, displaying results in Openlayers.
> For specific needs, we implemented Openlayers as WMS viewer in
> Geosource (GeoNetwork including profil for France).
> Openlayers, at this time, does not provide Intermap advanced
> functionnality such as PDF printing, web map context and map
> annotations, this is a current limitation.
> Concerning Mapfish, there is no plan to integrate it as a GUI for
> Geonetwork but interaction between both will probably be developed in
> the coming month.
> Cheers,
> Mathieu
> On Tue, May 20, 2008 at 2:23 PM, Cameron Shorter
> <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>> wrote:
> Openlayers developers,
> LISAsoft has been hired to improved the User Interface for Geonetwork
> and we will be kicking off the project tomorrow.
> Jeroen tells me that Camp2Camp has already been looking into
> building a
> GUI for Geonetwork. Is this true?
> If so, what is the state of this Camp2Camp work? Where are you up
> to? Do
> you have anything that we can contribute to or build upon?
> Cameron Shorter
> Geospatial Systems Architect
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Commercial Support for Geospatial Open Source Solutions
> http://www.lisasoft.com/LISAsoft/SupportedProducts.html
> Dev mailing list
> Dev at openlayers.org <mailto:Dev at openlayers.org>
> http://openlayers.org/mailman/listinfo/dev
> Mathieu Coudert
> mcoudert at gmail.com <mailto:mcoudert at gmail.com>
Cameron Shorter
More information about the Dev
