[OpenLayers-Dev] xml_eq and geom_eq
Tim Schaub
tschaub at opengeo.org
Tue Nov 4 16:07:26 EST 2008
Hey-
I don't think I sent out a message about this before. A while ago, I
added a geom_eq method to the test objects from Test.AnotherWay.
This lets you do things like:
function test_soup(t) {
t.plan(1);
var format = new OpenLayers.Format.WKT();
var wkt = "POINT(10 20)";
var geom = new OpenLayers.Geometry.Point(10, 20);
var feature = format.read(wkt);
t.geom_eq(feature.geometry, geom, "point read");
All geometry types supported.
This and the xml_eq method (compare nodes to nodes, nodes to strings,
etc) should make test writing a bit more compact if nothing else.
Both are documented here:
http://trac.openlayers.org/wiki/WritingUnitTests#ModificationstoTest.AnotherWay
Tim
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
