[OpenLayers-Dev] Access denied for MapGuide Overlayer (with patched MapGuide.js)
Carl carlshe at 163.com
Thu Nov 6 08:50:33 EST 2008
It seems solved with the newest patch based on MSOS of 2.0.3 higher.
But MGOS 2.0.3/2.1 isn't released yet.
Carl wrote:
> I integrate more than one MapGuide Layers from different MG OS Servers,
> one is as base layer, which works very well, and others as overlayers,
> which meet always the problem of 'Access denied'.
> It seems being caused by the synchrous request...
> I found a new patch to MapGuide.js
> (http://trac.openlayers.org/attachment/ticket/1756/MGAsynchOverlay.patch)
> and try it with new example
> (http://trac.openlayers.org/attachment/ticket/1757/MGexample.patch). But
> the same problem is still there.
> I sincerely hope the MapGuide Layer can be improved (without the support
> of 'Proxy.cgi') as soon as possible.
> Thanks.
View this message in context: http://www.nabble.com/Access-denied-for-MapGuide-Overlayer-%28with-patched-MapGuide.js%29-tp19882699p20361385.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
