[OpenLayers-Dev] clearing handlers
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Sun Nov 9 10:38:27 EST 2008
No I can't.
Best regards,
Bart
Christopher Schmidt wrote:
> On Fri, Nov 07, 2008 at 09:13:59AM +0100, Bart van den Eijnden (OSGIS) wrote:
>> Right that was my concern, and my use case used to be (the bug is now
>> fixed fortunately) clearing the sketch layer of the measure control.
>> Since the measure control can have different types of Handlers I would
>> now need to do different things according to which is the underlying
>> Handler.
> Can you describe a use case that doesn't involve working around a known
> bug? (if there are bugs in the code you are using that affect you,
> really, all bets are off.)
> Regards,
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev
