[OpenLayers-Dev] clearing handlers
Christopher Schmidt
crschmidt at metacarta.com
Sun Nov 9 03:32:12 EST 2008
On Fri, Nov 07, 2008 at 09:13:59AM +0100, Bart van den Eijnden (OSGIS) wrote:
> Right that was my concern, and my use case used to be (the bug is now
> fixed fortunately) clearing the sketch layer of the measure control.
> Since the measure control can have different types of Handlers I would
> now need to do different things according to which is the underlying
> Handler.
Can you describe a use case that doesn't involve working around a known
bug? (if there are bugs in the code you are using that affect you,
really, all bets are off.)
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
