[OpenLayers-Dev] Cluster strategy getResolution bug ?
Ivan Grcic ivan.grcic at geofoto.hr
Fri Nov 7 18:04:22 EST 2008
And i think it might be connected to with
http://www.nabble.com/Cluster-and-Scales-map-options-td20224740.html#a20224740
On Sat, Nov 8, 2008 at 12:00 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
> Yup, and i was about to fill this one too :)
> Did u fill the ticket allready?
> On Fri, Nov 7, 2008 at 10:30 PM, Alexandre Dube <adube at mapgears.com> wrote:
>> Hi devs,
>>  I got a problem using the cluster strategy.  At first, it didn't
>> seemed to work at all.  I always got the same number of feature with or
>> without the cluster strategy applied.  After a few search, I found out
>> the problem was at line 143 : *var* resolution =
>> *this*.layer.getResolution();
>>  I just replaced the line for : *var* resolution =
>> *this*.layer.map.getResolution(); and it worked.
>>  The reason is :
>>  My base layer has 10 fixed scales ( which gives 10 resolutions), from
>> 0 to 9.  My vector layer has only 7, which represents resolutions 3 to 9
>> of the base layer's scales, but the vector layer itself has his own
>> scales array from 0 to 6.  So, the line 143 which called resolution 3
>> from the base layer calls resolution 3 from the vector layer, which is
>> wrong !
>>  Anyone else noticed this ?
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Ivan Grcic
Ivan Grcic
More information about the Dev mailing list
