[OpenLayers-Dev] Cluster strategy getResolution bug ?
Ivan Grcic
ivan.grcic at geofoto.hr
Fri Nov 7 18:00:06 EST 2008
Yup, and i was about to fill this one too :)
Did u fill the ticket allready?
On Fri, Nov 7, 2008 at 10:30 PM, Alexandre Dube <adube at mapgears.com> wrote:
> Hi devs,
> I got a problem using the cluster strategy. At first, it didn't
> seemed to work at all. I always got the same number of feature with or
> without the cluster strategy applied. After a few search, I found out
> the problem was at line 143 : *var* resolution =
> *this*.layer.getResolution();
> I just replaced the line for : *var* resolution =
> *this*.layer.map.getResolution(); and it worked.
> The reason is :
> My base layer has 10 fixed scales ( which gives 10 resolutions), from
> 0 to 9. My vector layer has only 7, which represents resolutions 3 to 9
> of the base layer's scales, but the vector layer itself has his own
> scales array from 0 to 6. So, the line 143 which called resolution 3
> from the base layer calls resolution 3 from the vector layer, which is
> wrong !
> Anyone else noticed this ?
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Ivan Grcic
More information about the Dev
