[OpenLayers-Dev] popup closebox issue
Jerome Freyre jerome.freyre at hispeed.ch
Mon Nov 10 10:47:24 EST 2008
It's really strange...
Maybe can you try to update your safari and check the example again?
Personnaly, I use Windows Vista...
euzuro wrote:
> This is really wierd. I just checked again and it's there.
> again, win xp safari 3.0.4
> I have no explanation for this, apologies.
> On Mon, Nov 10, 2008 at 2:31 AM, Jerome Freyre
> <jerome.freyre at hispeed.ch>wrote:
>> Hi Eric and euzuro,
>> I tried the example : http://openlayers.org/dev/examples/popupMatrix.html
>> On my pc with safari 3.1.2 and the closebox is correctly working and
>> rendered...
>> Wich version of safari are you using?
>> Jerome Freyre wrote:
>> > Hi Eric,
>> > There is no problem with the popup closebox on Safari with a mac...
>> > I'll try this week end on my pc with safari...
>> > Eric Lemoine-3 wrote:
>> >> Hello
>> >> I noticed that the popup closebox is not rendered on Safari (Safari
>> >> 3.0.3 on Windows). Has anyone else experienced that? Is the problem
>> >> existing on Safari on Mac as well?
>> >> Thanks,
>> >> Eric
>> >> _______________________________________________
>> >> Dev mailing list
>> >> Dev at openlayers.org
>> >> http://openlayers.org/mailman/listinfo/dev
>> View this message in context:
>> http://www.nabble.com/popup-closebox-issue-tp20378034p20416102.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
> Dev mailing list
View this message in context: http://www.nabble.com/popup-closebox-issue-tp20378034p20422410.html
More information about the Dev mailing list
