[OpenLayers-Dev] popup closebox issue
Erik Uzureau euzuro at gmail.com
Mon Nov 10 10:49:48 EST 2008
Sorry, I don't explain myself correctly... I just tried it again and the
popup close box IS there.
The first time I tried this (last week?) I opened the same example and I
swear it wasn't there.
again, sorry for the confusion.
erik
On Mon, Nov 10, 2008 at 9:47 AM, Jerome Freyre <jerome.freyre at hispeed.ch>wrote:
> It's really strange...
> Maybe can you try to update your safari and check the example again?
> Personnaly, I use Windows Vista...
> euzuro wrote:
> > This is really wierd. I just checked again and it's there.
> > again, win xp safari 3.0.4
> > I have no explanation for this, apologies.
> > On Mon, Nov 10, 2008 at 2:31 AM, Jerome Freyre
> >> Hi Eric and euzuro,
> >> I tried the example :
> http://openlayers.org/dev/examples/popupMatrix.html
> >> On my pc with safari 3.1.2 and the closebox is correctly working and
> >> rendered...
> >> Wich version of safari are you using?
> >> Jerome Freyre wrote:
> >> > Hi Eric,
> >> > There is no problem with the popup closebox on Safari with a mac...
> >> > I'll try this week end on my pc with safari...
> >> > Eric Lemoine-3 wrote:
> >> >> Hello
> >> >> I noticed that the popup closebox is not rendered on Safari (Safari
> >> >> 3.0.3 on Windows). Has anyone else experienced that? Is the problem
> >> >> existing on Safari on Mac as well?
> >> >> Thanks,
> >> >> Eric
> >> >> _______________________________________________
> >> >> Dev mailing list
> >> >> Dev at openlayers.org
> >> >> http://openlayers.org/mailman/listinfo/dev
> >> View this message in context:
> >> http://www.nabble.com/popup-closebox-issue-tp20378034p20416102.html
> >> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> >> Dev mailing list
> > Dev mailing list
> http://www.nabble.com/popup-closebox-issue-tp20378034p20422410.html
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081110/05d41527/attachment.html
More information about the Dev mailing list
