[OpenLayers-Dev] popup closebox issue
Jerome Freyre jerome.freyre at hispeed.ch
Mon Nov 10 10:55:09 EST 2008
I must sorry me too...
I did not read english very good and I misunderstood you...
It's really strange...
Hope it is also working on Eric Lemoine's computer...
Sincerly,
Jérome
euzuro wrote:
> Sorry, I don't explain myself correctly... I just tried it again and the
> popup close box IS there.
> The first time I tried this (last week?) I opened the same example and I
> swear it wasn't there.
> again, sorry for the confusion.
> erik
> On Mon, Nov 10, 2008 at 9:47 AM, Jerome Freyre
>> Maybe can you try to update your safari and check the example again?
>> Personnaly, I use Windows Vista...
>> euzuro wrote:
>> > This is really wierd. I just checked again and it's there.
>> > again, win xp safari 3.0.4
>> > I have no explanation for this, apologies.
>> > On Mon, Nov 10, 2008 at 2:31 AM, Jerome Freyre
>> >> Hi Eric and euzuro,
>> >> I tried the example :
>> http://openlayers.org/dev/examples/popupMatrix.html
>> >> On my pc with safari 3.1.2 and the closebox is correctly working and
>> >> rendered...
>> >> Wich version of safari are you using?
>> >> Jerome Freyre wrote:
>> >> > Hi Eric,
>> >> > There is no problem with the popup closebox on Safari with a mac...
>> >> > I'll try this week end on my pc with safari...
>> >> > Eric Lemoine-3 wrote:
>> >> >> Hello
>> >> >> I noticed that the popup closebox is not rendered on Safari (Safari
>> >> >> 3.0.3 on Windows). Has anyone else experienced that? Is the problem
>> >> >> existing on Safari on Mac as well?
>> >> >> Thanks,
>> >> >> Eric
>> >> >> _______________________________________________
>> >> >> Dev mailing list
>> >> >> Dev at openlayers.org
>> >> >> http://openlayers.org/mailman/listinfo/dev
>> >> View this message in context:
>> >> http://www.nabble.com/popup-closebox-issue-tp20378034p20416102.html
>> >> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> >> Dev mailing list
>> > Dev mailing list
>> http://www.nabble.com/popup-closebox-issue-tp20378034p20422410.html
>> Dev mailing list
> Dev mailing list
View this message in context: http://www.nabble.com/popup-closebox-issue-tp20378034p20422562.html
More information about the Dev mailing list
