[OpenLayers-Dev] Call for Votes: LoadingPanel addin
Ivan Grcic
ivan.grcic at geofoto.hr
Tue Nov 11 04:30:02 EST 2008
Tnx Bart, i didnt know that z-indexes are set according to order of
adding them to the map. It works fine like that!
But thers other problem now.. I have option to enable/disable
laodingPanel control, and control.activate() & control.deactivate()
deosnt seem to function... so then I completely remove/add control,
something like:
if(checked){
map.addControl(new OpenLayers.Control.LoadingPanel());
else {
map.removeControl(map.getControlsByClass('OpenLayers.Control.LoadingPanel')[0]);
and then laodingPanel control comes up again with same problem. Is
there a way to get lowest z-index and then set laodingPanel below it?
Tnx,
Ivan
On Tue, Nov 11, 2008 at 9:08 AM, <bartvde at osgis.nl> wrote:
> Hi Ivan,
> and what if you add the LoadingPanel as the first control to the map? It
> will have the lowest zIndex than of the controls inside of the viewport.
> The PanZoomBar will be clickable then.
> map = new OpenLayers.Map( 'map', { controls: [] });
> map.addControl( new OpenLayers.Control.LoadingPanel());
> map.addControl(new OpenLayers.Control.PanZoomBar());
> If this does not help, can you post an example HTML to reproduce this?
> Best regards,
> Bart
>> Hi,
>> i discovered little (but annoying) bug in LoadingPanel addin. When
>> loading panel is active, it takes away click control from PanZoomBar
>> control, but it propagates further to map. So if for an example you
>> have getFeatureInfo activated onclick (on map), and you click on
>> PanZoomBar it doestn move/zoom the map but activates getFeatureinfo...
>> i guess its because of the order od z-index , right?
>> On Sun, Aug 31, 2008 at 5:40 PM, Bart van den Eijnden (OSGIS)
>>> This is getting embarassing :-)
>>> That's what you get when you move something from a sandbox and don't
>>> check (also because it takes a while to be published to the webserver).
>>> Should be fixed now, sorry.
>>> Best regards,
>>> Bart
>>> Ivan Grcic wrote:
>>>> Hehe, error again :)
>>>> <script src="http://openlayers.org/dev/lib/OpenLayers.js"></script> Is
>>>> not compiled with loadingPanel plugin, so you have to include it
>>>> seperatly then:
>>>> <script src="../lib/OpenLayers/Control/LoadingPanel.js">
>>>> cheers
>>>> On Sun, Aug 31, 2008 at 10:50 AM, Bart van den Eijnden (OSGIS)
>>>>> Hi Ivan,
>>>>> thanks for spotting this, fixed in svn.
>>>>> Best regards,
>>>>> Bart
>>>>> Ivan Grcic wrote:
>>>>>> Sweet, just one litle thing
>>>>>> http://dev.openlayers.org/addins/loadingPanel/trunk/examples/loadingpanel.html
>>>>>> is not working right, thers not
>>>>>> <script src="../lib/OpenLayers.js"></script>
>>>>>> Cherrs, Ivan
>>>>>> On Sat, Aug 30, 2008 at 9:18 PM, Bart van den Eijnden (OSGIS)
>>>>>>> Hi Erik,
>>>>>>> the loadingpanel addin svn is set up and the Wiki page has been
>>>>>>> adapted.
>>>>>>> Best regards,
>>>>>>> Bart
>>>>>>> Erik Uzureau wrote:
>>>>>>>> Like the bookmark control, the LoadingPanel seems to have universal
>>>>>>>> support,
>>>>>>>> so I have gone ahead and made the /addins/loadingPanel directory.
>>>>>>>> When you have a moment, bart.. please go ahead and set up the
>>>>>>>> directory structure
>>>>>>>> for loadingPanel... and when you're ready, let us know with an
>>>>>>>> announcement
>>>>>>>> email.
>>>>>>>> Again, Congrats! I know for a fact that *many* people out there
>>>>>>>> have
>>>>>>>> been looking
>>>>>>>> for a tool like this... this is a great addition to the !OpenLayers
>>>>>>>> project.
>>>>>>>> Cheers,
>>>>>>>> Erik
>>>>>>>> On Wed, Aug 27, 2008 at 12:16 AM, Erik Uzureau <euzuro at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Nobody seemed to notice my vote in the old thread so I'm starting
>>>>>>>>> it
>>>>>>>>> anew:
>>>>>>>>> I am +1 for getting bartvde's loadingpanel code into the /addins
>>>>>>>>> directory.
>>>>>>>>> If you have an opinion, please speak up.
>>>>>>>>> e
>>>>>>>>> For more info, see:
>>>>>>>>> http://trac.openlayers.org/wiki/Addins/LoadingPanel
>>>>>>>> _______________________________________________
>>>>>>>> Dev mailing list
>>>>>>>> Dev at openlayers.org
>>>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>>>>> OSGIS, Open Source GIS
>>>>>>> bartvde at osgis.nl
>>>>>>> http://www.osgis.nl
>>>>>>> Dev mailing list
>>>>> bartvde at osgis.nl
>>>>> http://www.osgis.nl
>>> bartvde at osgis.nl
>>> http://www.osgis.nl
>>> Dev mailing list
>> Ivan Grcic
Ivan Grcic
More information about the Dev
