[OpenLayers-Dev] Call for Votes: LoadingPanel addin
bartvde at osgis.nl
bartvde at osgis.nl
Tue Nov 11 05:20:38 EST 2008
Hi Ivan,
I see your problem, I have just added a hide, show and toggle method to
the loadingpanel control which should accommodate your use case. If it
does not work for you, let me know.
Please update the loadingpanel addin from svn, I've also updated the
example with a simple toggle.
http://trac.openlayers.org/changeset/8319
Best regards,
Bart
> Tnx Bart, i didnt know that z-indexes are set according to order of
> adding them to the map. It works fine like that!
> But thers other problem now.. I have option to enable/disable
> laodingPanel control, and control.activate() & control.deactivate()
> deosnt seem to function... so then I completely remove/add control,
> something like:
> if(checked){
> map.addControl(new OpenLayers.Control.LoadingPanel());
> else {
> map.removeControl(map.getControlsByClass('OpenLayers.Control.LoadingPanel')[0]);
> and then laodingPanel control comes up again with same problem. Is
> there a way to get lowest z-index and then set laodingPanel below it?
> Tnx,
> Ivan
> On Tue, Nov 11, 2008 at 9:08 AM, <bartvde at osgis.nl> wrote:
>> Hi Ivan,
>> and what if you add the LoadingPanel as the first control to the map? It
>> will have the lowest zIndex than of the controls inside of the viewport.
>> The PanZoomBar will be clickable then.
>> map = new OpenLayers.Map( 'map', { controls: [] });
>> map.addControl( new OpenLayers.Control.LoadingPanel());
>> map.addControl(new OpenLayers.Control.PanZoomBar());
>> If this does not help, can you post an example HTML to reproduce this?
>> Best regards,
>> Bart
>>> Hi,
>>> i discovered little (but annoying) bug in LoadingPanel addin. When
>>> loading panel is active, it takes away click control from PanZoomBar
>>> control, but it propagates further to map. So if for an example you
>>> have getFeatureInfo activated onclick (on map), and you click on
>>> PanZoomBar it doestn move/zoom the map but activates getFeatureinfo...
>>> i guess its because of the order od z-index , right?
>>> On Sun, Aug 31, 2008 at 5:40 PM, Bart van den Eijnden (OSGIS)
>>>> This is getting embarassing :-)
>>>> That's what you get when you move something from a sandbox and don't
>>>> check (also because it takes a while to be published to the
>>>> webserver).
>>>> Should be fixed now, sorry.
>>>> Best regards,
>>>> Bart
>>>> Ivan Grcic wrote:
>>>>> Hehe, error again :)
>>>>> <script src="http://openlayers.org/dev/lib/OpenLayers.js"></script>
>>>>> Is
>>>>> not compiled with loadingPanel plugin, so you have to include it
>>>>> seperatly then:
>>>>> <script src="../lib/OpenLayers/Control/LoadingPanel.js">
>>>>> cheers
>>>>> On Sun, Aug 31, 2008 at 10:50 AM, Bart van den Eijnden (OSGIS)
>>>>>> Hi Ivan,
>>>>>> thanks for spotting this, fixed in svn.
>>>>>> Best regards,
>>>>>> Bart
>>>>>> Ivan Grcic wrote:
>>>>>>> Sweet, just one litle thing
>>>>>>> http://dev.openlayers.org/addins/loadingPanel/trunk/examples/loadingpanel.html
>>>>>>> is not working right, thers not
>>>>>>> <script src="../lib/OpenLayers.js"></script>
>>>>>>> Cherrs, Ivan
>>>>>>> On Sat, Aug 30, 2008 at 9:18 PM, Bart van den Eijnden (OSGIS)
>>>>>>>> Hi Erik,
>>>>>>>> the loadingpanel addin svn is set up and the Wiki page has been
>>>>>>>> adapted.
>>>>>>>> Best regards,
>>>>>>>> Bart
>>>>>>>> Erik Uzureau wrote:
>>>>>>>>> Like the bookmark control, the LoadingPanel seems to have
>>>>>>>>> universal
>>>>>>>>> support,
>>>>>>>>> so I have gone ahead and made the /addins/loadingPanel directory.
>>>>>>>>> When you have a moment, bart.. please go ahead and set up the
>>>>>>>>> directory structure
>>>>>>>>> for loadingPanel... and when you're ready, let us know with an
>>>>>>>>> announcement
>>>>>>>>> email.
>>>>>>>>> Again, Congrats! I know for a fact that *many* people out there
>>>>>>>>> have
>>>>>>>>> been looking
>>>>>>>>> for a tool like this... this is a great addition to the
>>>>>>>>> !OpenLayers
>>>>>>>>> project.
>>>>>>>>> Cheers,
>>>>>>>>> Erik
>>>>>>>>> On Wed, Aug 27, 2008 at 12:16 AM, Erik Uzureau <euzuro at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Nobody seemed to notice my vote in the old thread so I'm
>>>>>>>>>> starting
>>>>>>>>>> it
>>>>>>>>>> anew:
>>>>>>>>>> I am +1 for getting bartvde's loadingpanel code into the /addins
>>>>>>>>>> directory.
>>>>>>>>>> If you have an opinion, please speak up.
>>>>>>>>>> e
>>>>>>>>>> For more info, see:
>>>>>>>>>> http://trac.openlayers.org/wiki/Addins/LoadingPanel
>>>>>>>>> _______________________________________________
>>>>>>>>> Dev mailing list
>>>>>>>>> Dev at openlayers.org
>>>>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>>>>>> OSGIS, Open Source GIS
>>>>>>>> bartvde at osgis.nl
>>>>>>>> http://www.osgis.nl
>>>>>>>> Dev mailing list
>>>>>> bartvde at osgis.nl
>>>>>> http://www.osgis.nl
>>>> bartvde at osgis.nl
>>>> http://www.osgis.nl
>>>> Dev mailing list
>>> Ivan Grcic
> Ivan Grcic
More information about the Dev
