[OpenLayers-Dev] Call for Votes: LoadingPanel addin
Erik Uzureau
euzuro at gmail.com
Tue Nov 11 12:25:43 EST 2008
Great work on keeping this up to date, Bart.
It's great to see that the LoadingPanel is getting some use!
Erik
On Tue, Nov 11, 2008 at 4:20 AM, <bartvde at osgis.nl> wrote:
> Hi Ivan,
> I see your problem, I have just added a hide, show and toggle method to
> the loadingpanel control which should accommodate your use case. If it
> does not work for you, let me know.
> Please update the loadingpanel addin from svn, I've also updated the
> example with a simple toggle.
> http://trac.openlayers.org/changeset/8319
> Best regards,
> Bart
> > Tnx Bart, i didnt know that z-indexes are set according to order of
> > adding them to the map. It works fine like that!
> > But thers other problem now.. I have option to enable/disable
> > laodingPanel control, and control.activate() & control.deactivate()
> > deosnt seem to function... so then I completely remove/add control,
> > something like:
> > if(checked){
> > map.addControl(new OpenLayers.Control.LoadingPanel());
> > else {
> map.removeControl(map.getControlsByClass('OpenLayers.Control.LoadingPanel')[0]);
> > and then laodingPanel control comes up again with same problem. Is
> > there a way to get lowest z-index and then set laodingPanel below it?
> > Tnx,
> > Ivan
> > On Tue, Nov 11, 2008 at 9:08 AM, <bartvde at osgis.nl> wrote:
> >> Hi Ivan,
> >> and what if you add the LoadingPanel as the first control to the map? It
> >> will have the lowest zIndex than of the controls inside of the viewport.
> >> The PanZoomBar will be clickable then.
> >> map = new OpenLayers.Map( 'map', { controls: [] });
> >> map.addControl( new OpenLayers.Control.LoadingPanel());
> >> map.addControl(new OpenLayers.Control.PanZoomBar());
> >> If this does not help, can you post an example HTML to reproduce this?
> >> Best regards,
> >> Bart
> >>> Hi,
> >>> i discovered little (but annoying) bug in LoadingPanel addin. When
> >>> loading panel is active, it takes away click control from PanZoomBar
> >>> control, but it propagates further to map. So if for an example you
> >>> have getFeatureInfo activated onclick (on map), and you click on
> >>> PanZoomBar it doestn move/zoom the map but activates getFeatureinfo...
> >>> i guess its because of the order od z-index , right?
> >>> On Sun, Aug 31, 2008 at 5:40 PM, Bart van den Eijnden (OSGIS)
> >>>> This is getting embarassing :-)
> >>>> That's what you get when you move something from a sandbox and don't
> >>>> check (also because it takes a while to be published to the
> >>>> webserver).
> >>>> Should be fixed now, sorry.
> >>>> Best regards,
> >>>> Bart
> >>>> Ivan Grcic wrote:
> >>>>> Hehe, error again :)
> >>>>> <script src="http://openlayers.org/dev/lib/OpenLayers.js"></script>
> >>>>> Is
> >>>>> not compiled with loadingPanel plugin, so you have to include it
> >>>>> seperatly then:
> >>>>> <script src="../lib/OpenLayers/Control/LoadingPanel.js">
> >>>>> cheers
> >>>>> On Sun, Aug 31, 2008 at 10:50 AM, Bart van den Eijnden (OSGIS)
> >>>>>> Hi Ivan,
> >>>>>> thanks for spotting this, fixed in svn.
> >>>>>> Best regards,
> >>>>>> Bart
> >>>>>> Ivan Grcic wrote:
> >>>>>>> Sweet, just one litle thing
> http://dev.openlayers.org/addins/loadingPanel/trunk/examples/loadingpanel.html
> >>>>>>> is not working right, thers not
> >>>>>>> <script src="../lib/OpenLayers.js"></script>
> >>>>>>> Cherrs, Ivan
> >>>>>>> On Sat, Aug 30, 2008 at 9:18 PM, Bart van den Eijnden (OSGIS)
> >>>>>>>> Hi Erik,
> >>>>>>>> the loadingpanel addin svn is set up and the Wiki page has been
> >>>>>>>> adapted.
> >>>>>>>> Best regards,
> >>>>>>>> Bart
> >>>>>>>> Erik Uzureau wrote:
> >>>>>>>>> Like the bookmark control, the LoadingPanel seems to have
> >>>>>>>>> universal
> >>>>>>>>> support,
> >>>>>>>>> so I have gone ahead and made the /addins/loadingPanel directory.
> >>>>>>>>> When you have a moment, bart.. please go ahead and set up the
> >>>>>>>>> directory structure
> >>>>>>>>> for loadingPanel... and when you're ready, let us know with an
> >>>>>>>>> announcement
> >>>>>>>>> email.
> >>>>>>>>> Again, Congrats! I know for a fact that *many* people out there
> >>>>>>>>> have
> >>>>>>>>> been looking
> >>>>>>>>> for a tool like this... this is a great addition to the
> >>>>>>>>> !OpenLayers
> >>>>>>>>> project.
> >>>>>>>>> Cheers,
> >>>>>>>>> Erik
> >>>>>>>>> On Wed, Aug 27, 2008 at 12:16 AM, Erik Uzureau <euzuro at gmail.com
> >>>>>>>>> wrote:
> >>>>>>>>>> Nobody seemed to notice my vote in the old thread so I'm
> >>>>>>>>>> starting
> >>>>>>>>>> it
> >>>>>>>>>> anew:
> >>>>>>>>>> I am +1 for getting bartvde's loadingpanel code into the /addins
> >>>>>>>>>> directory.
> >>>>>>>>>> If you have an opinion, please speak up.
> >>>>>>>>>> e
> >>>>>>>>>> For more info, see:
> >>>>>>>>>> http://trac.openlayers.org/wiki/Addins/LoadingPanel
> >>>>>>>>> _______________________________________________
> >>>>>>>>> Dev mailing list
> >>>>>>>>> Dev at openlayers.org
> >>>>>>>>> http://openlayers.org/mailman/listinfo/dev
> >>>>>>>> OSGIS, Open Source GIS
> >>>>>>>> bartvde at osgis.nl
> >>>>>>>> http://www.osgis.nl
> >>>>>>>> Dev mailing list
> >>>>>> bartvde at osgis.nl
> >>>>>> http://www.osgis.nl
> >>>> bartvde at osgis.nl
> >>>> http://www.osgis.nl
> >>>> Dev mailing list
> >>> Ivan Grcic
> > Ivan Grcic
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081111/b2b96926/attachment.html
More information about the Dev
