[OpenLayers-Dev] Storing styles as SLD
bartvde at osgis.nl
bartvde at osgis.nl
Tue Nov 11 09:41:25 EST 2008
Hi Carsten,
I've posted some of my code to pastebin, hopefully it will help you. Btw
SLD does not *need* the filters, a Rule can perfectly be valid without a
filter.
http://pastebin.com/m42ddc858
Best regards,
Bart
> first and best answer to my problem upto now
> where come your symbolizers and filters from ?
> how did you instantiate them ?
> bartvde at osgis.nl schrieb:
>> Hi,
>> SLD needs more stuff, e.g. NamedLayers and UserStyles. I am using the
>> following but I am not sure if this will still work in 2.7.
>> var sld = {version: "1.0.0", namedLayers: {}};
>> for (var i=0; i<layerNames.length; i++) {
>> sld.namedLayers[layerNames[i]] = {name: layerNames[i],
>> userStyles:
>> sld.namedLayers[layerNames[i]].userStyles.push({rules: []});
>> sld.namedLayers[layerNames[i]].userStyles[0].rules.push(
>> new OpenLayers.Rule({symbolizer: symbolizers[i], filter:
>> filters[i]}));
>> var frmt = new OpenLayers.Format.SLD();
>> return frmt.write(sld);
>> Best regards,
>> Bart
>>> Hi list,
>>> im a working on a webbased editor.
>>> Manipulating geometries works fine, changing color too.
>>> But now i want to store my changed styles as SLD
>>> CODE:
>>> var myStyles = new OpenLayers.StyleMap({
>>> "default": new OpenLayers.Style({
>>> pointRadius: "5", // sized according to type attribute
>>> fillColor: "#ffcc66",
>>> strokeColor: "#ff9933",
>>> strokeWidth: 2
>>> "select": new OpenLayers.Style({
>>> fillColor: "#66ccff",
>>> strokeColor: "#3399ff"
>>> var _sld=new OpenLayers.Format.SLD();
>>> var _style=myStyles.styles['default'];
>>> var _xml=_sld.write(_style);
>>> console.log(_xml);
>>> Result in console:
>>> <StyledLayerDescriptor xmlns="http://www.opengis.net/sld"
>>> version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld
>>> http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd"
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
>>> Any ideas why my xml keeps empty? I cannot see an error?
>>> thx Carsten
>>> Mit freundlichen Grüßen / Yours faithfully
>>> Carsten Eider
>>> Dipl. Inf. (FH)
>>> Kompetenzzentrum für Innovative Informationssysteme
>>> c/o Fachhochschhule Bingen / University of applied sciences Bingen
>>> Berlinstraße 109
>>> 55411 Bingen
>>> Tel: +49 (0) 6721 / 409-179
>>> Fax: +49 (0) 6721 / 409-158
>>> email: eider at fh-bingen.de
>>> Internet: iis.fh-bingen.de
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
> Carsten Eider
> Dipl. Inf. (FH)
> Berlinstraße 109
> 55411 Bingen
More information about the Dev
