[OpenLayers-Dev] Storing styles as SLD
Tim Schaub
tschaub at opengeo.org
Tue Nov 11 15:32:08 EST 2008
Hey-
bartvde at osgis.nl wrote:
> Hi Carsten,
> I've posted some of my code to pastebin, hopefully it will help you. Btw
> SLD does not *need* the filters, a Rule can perfectly be valid without a
> filter.
> http://pastebin.com/m42ddc858
> Best regards,
> Bart
>> first and best answer to my problem upto now
>> where come your symbolizers and filters from ?
>> how did you instantiate them ?
You can also read http://trac.openlayers.org/wiki/Styles
A rule has an optional filter. A symbolizer is an object with
properties to be used in drawing the feature.
Tim
>> bartvde at osgis.nl schrieb:
>>> Hi,
>>> SLD needs more stuff, e.g. NamedLayers and UserStyles. I am using the
>>> following but I am not sure if this will still work in 2.7.
>>> var sld = {version: "1.0.0", namedLayers: {}};
>>> for (var i=0; i<layerNames.length; i++) {
>>> sld.namedLayers[layerNames[i]] = {name: layerNames[i],
>>> userStyles:
>>> sld.namedLayers[layerNames[i]].userStyles.push({rules: []});
>>> sld.namedLayers[layerNames[i]].userStyles[0].rules.push(
>>> new OpenLayers.Rule({symbolizer: symbolizers[i], filter:
>>> filters[i]}));
>>> var frmt = new OpenLayers.Format.SLD();
>>> return frmt.write(sld);
>>> Best regards,
>>> Bart
>>>> Hi list,
>>>> im a working on a webbased editor.
>>>> Manipulating geometries works fine, changing color too.
>>>> But now i want to store my changed styles as SLD
>>>> CODE:
>>>> var myStyles = new OpenLayers.StyleMap({
>>>> "default": new OpenLayers.Style({
>>>> pointRadius: "5", // sized according to type attribute
>>>> fillColor: "#ffcc66",
>>>> strokeColor: "#ff9933",
>>>> strokeWidth: 2
>>>> "select": new OpenLayers.Style({
>>>> fillColor: "#66ccff",
>>>> strokeColor: "#3399ff"
>>>> var _sld=new OpenLayers.Format.SLD();
>>>> var _style=myStyles.styles['default'];
>>>> var _xml=_sld.write(_style);
>>>> console.log(_xml);
>>>> Result in console:
>>>> <StyledLayerDescriptor xmlns="http://www.opengis.net/sld"
>>>> version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld
>>>> http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd"
>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
>>>> Any ideas why my xml keeps empty? I cannot see an error?
>>>> thx Carsten
>>>> Mit freundlichen Grüßen / Yours faithfully
>>>> Carsten Eider
>>>> Dipl. Inf. (FH)
>>>> Kompetenzzentrum für Innovative Informationssysteme
>>>> c/o Fachhochschhule Bingen / University of applied sciences Bingen
>>>> Berlinstraße 109
>>>> 55411 Bingen
>>>> Tel: +49 (0) 6721 / 409-179
>>>> Fax: +49 (0) 6721 / 409-158
>>>> email: eider at fh-bingen.de
>>>> Internet: iis.fh-bingen.de
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>> Carsten Eider
>> Dipl. Inf. (FH)
>> Berlinstraße 109
>> 55411 Bingen
> Dev mailing list
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
