[OpenLayers-Dev] Bug in rendering features with cluster strategy
Ivan Grcic
ivan.grcic at geofoto.hr
Thu Nov 13 06:22:50 EST 2008
Sorry guys patch doesnt work! Im sticking with my own dirty hack
inside Layer.Vector drawFeature method...
On Fri, Nov 7, 2008 at 11:56 PM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
> Hey Alex...well actually i didnt catch time to try the patch...but
> before patch was made i created dirty hack that was working for me.
> Its not the best solution, but hey it works :)
> inside drawFeature just add one if statement
> function(feature, style) {
> if (OpenLayers.Util.indexOf(this.features, feature) != -1){
> (but for sure I will try the patch supplied in 1806 as soon as i can)
> On Fri, Nov 7, 2008 at 8:15 PM, Alexandre Dube <adube at mapgears.com> wrote:
>> Answer to my second question... still looking for the first...
>> >> If not, I would like to disable the wheel zoom. How can I do that ?
>> oNavCtrl = new OpenLayers.Control.Navigation(
>> { 'zoomWheelEnabled': false});
>> Alexandre Dube wrote:
>>> I tried this small patch but unfortunately the problem persist. Is there
>>> a new patch for this issue ( feature stays on screen when zooming with
>>> mouse over it with cluster strategy ) ?
>>> Alexandre
>>> Tim Schaub wrote:
>>>> Hey-
>>>> Eric Lemoine wrote:
>>>>> Yes. Especially since drawFeature is often called from addFeatures,
>>>>> where we're assured that the feature is in the layer. So, instead, we
>>>>> may want to change the select feature control so that it calls
>>>>> drawFeature only if, in the case of selection, the feature is in the
>>>>> "features" array, and in the case of unselection, the feature is in
>>>>> the "selectedFeatures" array. What do you think? Eric
>>>> The problem is in the Feature handler. We destroy features, but
>>>> references to them are still truthy. Since the destroy code sets the
>>>> layer property to null, one check of an undestroyed feature is to check
>>>> feature.layer.
>>>> See http://trac.openlayers.org/attachment/ticket/1806/destroyed.patch
>>>>> 2008/11/4, Tim Schaub <tschaub at opengeo.org>:
>>>>>> Hey-
>>>>>> Ivan Grcic wrote:
>>>>>>> OK... i found it..inside Layer.Vector...now the question is: should i
>>>>>>> put something like this:
>>>>>>> inside drawFeature: function(feature, style) {
>>>>>> Nope. Making drawFeature that safe at the expense of iterating through
>>>>>> every feature with every draw is a mistake.
>>>>>>> or inside every other function inside Layer.Vector that uses
>>>>>>> drawFeature function?
>>>>>>> When I put it here:
>>>>>>> --> if (OpenLayers.Util.indexOf(this.features, feature) != -1){
>>>>>>> it works pretty fine for me :) Eric?
>>>>>>> On Mon, Nov 3, 2008 at 9:53 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>>>>>>>> Yup, its not Cluster Strategy...
>>>>>>>> http://trac.openlayers.org/ticket/1806#comment:2
>>>>>>>> On Mon, Nov 3, 2008 at 9:11 AM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>>>>>>>>> Hi.
>>>>>>>>> Yes, this looks like a bug in OpenLayers.
>>>>>>>>> I'm under the impression that this isn't a bug in the cluster strategy
>>>>>>>>> but either in Layer.Vector or in Control.SelectFeature. Indeed, I
>>>>>>>>> think SelectFeature calls layer.drawFeature on feature
>>>>>>>>> selection/unselection without checking whether the feature is in the
>>>>>>>>> layer. And i'm saying this may be a bug in Layer.Vector because it may
>>>>>>>>> be that drawFeature should be responsible for checking whether the
>>>>>>>>> feature is in the layer before actually drawing it.
>>>>>>>>> This is just coming from the top of my head so i may be wrong, but i'm
>>>>>>>>> feeling this is a good track to follow :)
>>>>>>>>> Eric
>>>>>>>>> 2008/11/2, Ivan Grcic <ivan.grcic at geofoto.hr>:
>>>>>>>>>> Hi list,
>>>>>>>>>> i discovered a bug while developing my OL application, in cluster
>>>>>>>>>> strategy class.
>>>>>>>>>> Bug occurs when you hover over one feature that represent a cluster
>>>>>>>>>> (or externalGraphic or like in cluster example - vector circle
>>>>>>>>>> http://openlayers.org/dev/examples/strategy-cluster.html)
>>>>>>>>>> When you zoom in/out while that feature-cluster is selected (by
>>>>>>>>>> quickly double-clicking or easier using scroll on ur mouse), on next
>>>>>>>>>> zoom that cluster is rendered (stays on screen) together with newly
>>>>>>>>>> created clusters! And clearly it shouldnt be there. The old
>>>>>>>>>> ("phantom") cluster is not selectable, as he doesnt exist on the new
>>>>>>>>>> zoom level..he just stays there on screen...annoying me :)
>>>>>>>>>> As you zoom in again and again, phantom clusters always render, always
>>>>>>>>>> at the same position in the map div...
>>>>>>>>>> Please confirm that this is a bug, im going crazy here with this one :|
>>>>>>>>>> Ivan Grcic
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Dev mailing list
>>>>>>>>>> Dev at openlayers.org
>>>>>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>>>>>> Ivan Grcic
>>>>>> Tim Schaub
>>>>>> OpenGeo - http://opengeo.org
>>>>>> Expert service straight from the developers.
>>>>>> Dev mailing list
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Dev mailing list
> Ivan Grcic
Ivan Grcic
More information about the Dev
