[OpenLayers-Dev] Bug in rendering features with cluster strategy
Tim Schaub
tschaub at opengeo.org
Thu Nov 13 14:42:57 EST 2008
Hey-
Ivan Grcic wrote:
> Sorry guys patch doesnt work! Im sticking with my own dirty hack
> inside Layer.Vector drawFeature method...
Please provide more detail. Preferably on the ticket in question. It
is tough to provide solutions when the problems are this vague.
Thanks,
Tim
> On Fri, Nov 7, 2008 at 11:56 PM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>> Hey Alex...well actually i didnt catch time to try the patch...but
>> before patch was made i created dirty hack that was working for me.
>> Its not the best solution, but hey it works :)
>> inside drawFeature just add one if statement
>> function(feature, style) {
>> if (OpenLayers.Util.indexOf(this.features, feature) != -1){
>> (but for sure I will try the patch supplied in 1806 as soon as i can)
>> On Fri, Nov 7, 2008 at 8:15 PM, Alexandre Dube <adube at mapgears.com> wrote:
>>> Answer to my second question... still looking for the first...
>>> >> If not, I would like to disable the wheel zoom. How can I do that ?
>>> oNavCtrl = new OpenLayers.Control.Navigation(
>>> { 'zoomWheelEnabled': false});
>>> Alexandre Dube wrote:
>>>> I tried this small patch but unfortunately the problem persist. Is there
>>>> a new patch for this issue ( feature stays on screen when zooming with
>>>> mouse over it with cluster strategy ) ?
>>>> Alexandre
>>>> Tim Schaub wrote:
>>>>> Hey-
>>>>> Eric Lemoine wrote:
>>>>>> Yes. Especially since drawFeature is often called from addFeatures,
>>>>>> where we're assured that the feature is in the layer. So, instead, we
>>>>>> may want to change the select feature control so that it calls
>>>>>> drawFeature only if, in the case of selection, the feature is in the
>>>>>> "features" array, and in the case of unselection, the feature is in
>>>>>> the "selectedFeatures" array. What do you think? Eric
>>>>> The problem is in the Feature handler. We destroy features, but
>>>>> references to them are still truthy. Since the destroy code sets the
>>>>> layer property to null, one check of an undestroyed feature is to check
>>>>> feature.layer.
>>>>> See http://trac.openlayers.org/attachment/ticket/1806/destroyed.patch
>>>>>> 2008/11/4, Tim Schaub <tschaub at opengeo.org>:
>>>>>>> Hey-
>>>>>>> Ivan Grcic wrote:
>>>>>>>> OK... i found it..inside Layer.Vector...now the question is: should i
>>>>>>>> put something like this:
>>>>>>>> inside drawFeature: function(feature, style) {
>>>>>>> Nope. Making drawFeature that safe at the expense of iterating through
>>>>>>> every feature with every draw is a mistake.
>>>>>>>> or inside every other function inside Layer.Vector that uses
>>>>>>>> drawFeature function?
>>>>>>>> When I put it here:
>>>>>>>> --> if (OpenLayers.Util.indexOf(this.features, feature) != -1){
>>>>>>>> it works pretty fine for me :) Eric?
>>>>>>>> On Mon, Nov 3, 2008 at 9:53 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>>>>>>>>> Yup, its not Cluster Strategy...
>>>>>>>>> http://trac.openlayers.org/ticket/1806#comment:2
>>>>>>>>> On Mon, Nov 3, 2008 at 9:11 AM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>>>>>>>>>> Hi.
>>>>>>>>>> Yes, this looks like a bug in OpenLayers.
>>>>>>>>>> I'm under the impression that this isn't a bug in the cluster strategy
>>>>>>>>>> but either in Layer.Vector or in Control.SelectFeature. Indeed, I
>>>>>>>>>> think SelectFeature calls layer.drawFeature on feature
>>>>>>>>>> selection/unselection without checking whether the feature is in the
>>>>>>>>>> layer. And i'm saying this may be a bug in Layer.Vector because it may
>>>>>>>>>> be that drawFeature should be responsible for checking whether the
>>>>>>>>>> feature is in the layer before actually drawing it.
>>>>>>>>>> This is just coming from the top of my head so i may be wrong, but i'm
>>>>>>>>>> feeling this is a good track to follow :)
>>>>>>>>>> Eric
>>>>>>>>>> 2008/11/2, Ivan Grcic <ivan.grcic at geofoto.hr>:
>>>>>>>>>>> Hi list,
>>>>>>>>>>> i discovered a bug while developing my OL application, in cluster
>>>>>>>>>>> strategy class.
>>>>>>>>>>> Bug occurs when you hover over one feature that represent a cluster
>>>>>>>>>>> (or externalGraphic or like in cluster example - vector circle
>>>>>>>>>>> http://openlayers.org/dev/examples/strategy-cluster.html)
>>>>>>>>>>> When you zoom in/out while that feature-cluster is selected (by
>>>>>>>>>>> quickly double-clicking or easier using scroll on ur mouse), on next
>>>>>>>>>>> zoom that cluster is rendered (stays on screen) together with newly
>>>>>>>>>>> created clusters! And clearly it shouldnt be there. The old
>>>>>>>>>>> ("phantom") cluster is not selectable, as he doesnt exist on the new
>>>>>>>>>>> zoom level..he just stays there on screen...annoying me :)
>>>>>>>>>>> As you zoom in again and again, phantom clusters always render, always
>>>>>>>>>>> at the same position in the map div...
>>>>>>>>>>> Please confirm that this is a bug, im going crazy here with this one :|
>>>>>>>>>>> Ivan Grcic
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> Dev mailing list
>>>>>>>>>>> Dev at openlayers.org
>>>>>>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>>>>>>> Ivan Grcic
>>>>>>> Tim Schaub
>>>>>>> OpenGeo - http://opengeo.org
>>>>>>> Expert service straight from the developers.
>>>>>>> Dev mailing list
>>> Alexandre Dubé
>>> Mapgears
>>> www.mapgears.com
>>> Dev mailing list
>> Ivan Grcic
Tim Schaub
More information about the Dev
