[OpenLayers-Dev] bbox strategy and zooming
Tim Schaub tschaub at opengeo.org
Fri Nov 14 11:40:31 EST 2008
Hey-
Ivan Grcic wrote:
> Hi, ive tried Tims patch and i must say im pretty happy with it. Tnx Tim!
> I dont need to filter data depending on number of features
> (maxfeatures), but to show all the currently available data for area,
> then the cluster strategy jumps in and takes care that there are not
> too many features rendered. Perfect.
> Now the only problem is that one when upon activateing layer, it has
> to be nudged a bit for features to load (moveend effect)
Ivan, can you open a ticket and post an example that reproduces this
specific problem?  It would be great to have a record of it.  Also, if
you write back here with the ticket number, it would be good to have as
part of this thread.
Thanks,
Tim
> On Thu, Nov 13, 2008 at 9:08 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>> Thanks for putting this patch together Tim.
>> Initially Chris wanted that the bbox strategy behave aggressively on
>> zoom in, but, as an optimization, only if the number of features in
>> the layer is not lower than the maxfeatures value set in the protocol.
>> The change you're proposing wouldn't allow this. The change I proposed
>> involved adding a new Integer option to the bbox strategy. If that
>> option is null the strategy behaves as currently. If it's non-null
>> then it behaves aggressively if the number of features in the layer is
>> not lower than the option value.
>> Chris was concerned with configuration data duplication - maxfeatures
>> is kinda set in the protocol as well as in the strategy; which doesn't
>> bother me actually.
>> You may concerned with the fact that my proposed option targets a
>> specific case (maxfeatures-parameterized requests) and doesn't address
>> other, maybe more common, cases. I actually don't see other cases when
>> a more aggressive mode makes sense, but that's probably just me.
>> Cheers,
>> Eric
>> 2008/11/13, Tim Schaub <tschaub at opengeo.org>:
>>> Hey-
>>> Christopher Schmidt wrote:
>>>> I'm still lost as to how to go about coding what I want :) I want to
>>>> have maxfeatures, and more aggressive invalidation because of it. Any
>>>> suggestinos as to how I might go about implementing that, or should I
>>>> just toss together something and people will look at afterwards?
>>> If you haven't already tossed something together, see the patch for
>>> http://trac.openlayers.org/ticket/1830.
>>> Set resFactor to 1 if you want to request features with every change in
>>> resolution.
>>> Tim
>>>> Regards,
>>> Tim Schaub
>>> OpenGeo - http://opengeo.org
>>> Expert service straight from the developers.
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Dev mailing list
Tim Schaub
More information about the Dev mailing list
